The Watch Thread - Part 3
Paladium
Hello guys,
Would like to seek your opinion on this particular watch strap's color.
Is it suitable for work/formal attire - CBD area? Seems a bit loud.
Is your work place strict with your attire? Cause unless your work place or superiors are super anal over your attire/ dress code, as long as it matches your clothes i don't see why that strap wouldn't work.
If you want to be on the safe side then stick to black/brown and leave that for the weekends. :D
Henabi
agree. even thou if your office is located in CBD, it all boils down to your company, your department and your position.
if you're an Art Director, then being loud, funky n fashionable is perfectly fine.
if you're working in a bank or finance institution, then its safer to go with black, grey, navy blue or brown.
bencheongcm
anyone know where in Singapore can I get a brand new Seiko Samurai ? If i remember correctly it EOL already for this model right ?
jt2901
Anyone has an estimate of how much is the price of a tissot powermatic 80? The leather version with clasp. Not sure if I should get it at airport at the end of month.
yattokame
Changed to strap. Very nice crocodile strap from Italy. Poor camera skills and lighting. Actual stuff looks really good - old school charm :)
Erwinlow
assuming the watch is fine...
it stops after 1 day, does that means i'm not winding it enough?
generally, how many times do i wind the watch? until there is slight resistance or complete resistance?
Henabi
there should be an instruction manual telling you how to maintai. the watch and how many times n hoe often you need to wind it.
usually the SA may also verbally.tell you. like my auto 25hrs watch needs to wind 20-25 times.everyday in the morning
otherwise, its good to invest in a watch winder. it will help you to "wind" your watches when you're not wearing. you can buy from ebay or amazon.com
yukita
Its been more than a year after i got my stowa .... now repost again.... its been my daily beater ever since
took this picture 10 minutes ago :p
ComicBoy
Hi everyone
I am looking for an after market strap for a 48mm Zenith Pilot Montre D'Aeronef Annual Calendar. Size of strap is 24/22mm 115/75.
The strap lug seems to be unique (see photos). Hence, not sure if all after market straps will work.
Appreciate if anyone here can point me in the right direction where I can get one. I've actually looked through sg-roc but was not able to find any.
Thanks in advance for your help.
Henabi
very well maintained.... and your IBM thinkpad... jin classic sio
yukita
thank you.... i try to take a good care... but as it is a daily beater, abit difficult... but wear it without much worry this and that jin happy de :D
Samfreak
Hi everyone
Wow .. What a beauty! I'm not able to help but if you don't get the right help here, I suggest you pose your question at the Zenith brand forum at WUS. Someone there should be able to help.
