Official Battlefield 4 Thread
Rainowar
i will say that, this game feels like an arcade shooter perfect for a casual player like myself
Azharsinrix
My powercolor 7850 pcs+ can run leh.
I set at ultra, the movement quite slow
I set at high, the movement quite slow too
I set at medium, movement smooth.
I set at auto, the game auto adjust for me a mix of ultra and high settings. Movement smooth and tok kong!
I like the corner wall peek feature. Overall not bad but I feel that the mini map very hard to see enemies. I prefer bf3 mini map.
Found some bug also. Jump from building into water immediate plunge below the whole map. Can walk underneath lol
Most probably cause of my cpu :(
WoShiPro
Downloading Beta now.. got the game free lol...
Preorder but decide to cancel... gotten refund but EA nvr remove the game from my Origin.
socialjazz
this game is extremely CPU intensive. My frame rates varies from 40+ to 100+ on all Ultra no MSAA settings on 1600p resolution. My overclocked i71600k at 4.2Ghz cannot keep up with a constant >=60fps for this game.
shidenx
i like how sniping feels now. Got a very good clear bullet trail for you to judge. Hit box for head also smaller, got random slight bullet fall or float ... it just feels more realistic. Harder to spot snipers which is good and more fun.
Also like the fact that u cant spam ur vehicle weapons and have to wait till it reloads lol. Encourage you to make your shots count.
Rainowar
agreed pros and cons sniping in bf4 is easier and less technical as compared to bfbc2 or bf3 hence i coin the term "arcade shooter"
socialjazz
Lol 4k TV or down sample? What graphics card? That could be the bottle neck
30" 1600p monitor
graphic card should be ok. Titan SLI, but running on 2xPCIE2.0 16x lanes, should not reach saturation yet. 16GB G.Skill ram.
shidenx
heh bf3 sniper more arcade shooter leh.
now snipers cannot run in and out of cover to snipe ppl shooting without support.
The random factor seems to fudge ppl up alot when u shoot without support. Makes proning and bipod more useful than quick scoping COD style lol.
nakitaro
what gpu are you using now?
ps, reception here low. saw your reply on your current gpu specs..
maxsony
30" 1600p monitor
a lot of the people had mentioned liao in the bf4 forum. even a overclocked processor are getting high cpu usage whether on 4 core or with HT enabled.
only 1 can be explained is the game is making use of all core in the processor together with the graphic card render the graphic at the same time.
it is heavily multi-threaded .. making use of all core of your processor.
in the past, most of the games are only using at most 2 core to render, thus u wont able to see the high cpu usage.
it is still in beta.. you guys are beta tester. pretty sure the final version would solve such issues.
