Should WE talk about ROOT Note 3
dmstar
Now not wise to root note 3 due to Knox . if not hard tosend in warranty le
Keep our fingers crossed that perhaps very soon we can triangle away the knox's counter too!(seems like a low chance now, but u never know.. maybe a sinkie teenager might crack this:D )
Vulpix
Moderator
Moderator
Our sexpert chainfire already think it's going to be damn tough liao... :(
qqqinqqq
currently not rooting due to knox counter too... :(
vaxvms
no root whr got fun + rooting really save lotza of battery juice
as long as u know why u root and wat u doing is fine
dun follow wind to root for sake of root :)
flywithme
+1
I have been rooting all my android phone since G1 > G3 Hero > Desire HD > Xperia Play > Note > Note 2 > Note 3.
I flash custom rom very often too.
If you know what to do, you can save plenty of battery and increase very significant performance, not to mention making your phone smarter and prettier, running apps/games that never meant for your phone/processor/country...so much more.
nckeong88
I don't really see much risk. If soft brick can always fix it yourself. If totally cannot boot up, they can't even see knox counter.
Xerovix
sorry new to android. been on ios platform planning to try out Note3, just wonder if we can remove the root thingy before sending to service centre works ?
also no use.... knox will have it registered:(
FuzzyLop
Think the prob is HW failure what if your touch screen die etc must go wty.
ZhuTou!
Personal choice I guess, android phone feels handicapped without root...I tried without root fir 2days
Not really la
Iphone is the one handicapped without jailbreak
Android still ok
Can install many things without root
noblewolf
When I got this phone, of course first thing is put a screen protector, second is root and flash a deodexed Custom Rom.
Yes, lets put it this way. If you dont know what root is and why you need it.. Well, the truth is.. You dont need it.
vaxvms
+1
note 3 u so fast do?
so warranty void "at the moment" ?
vaxvms
Not really la
Android still ok
fruit bo pien need jailbreak as all wan free app
android got APK for most so need root
root for more control :)
ZhuTou!
ya certain app need root
i never root now coz of the counter thing
so i cant install certain app
wait for the updated root version first :D
flywithme
Actually there is a trick..
If you had a hardware breakdown(screen crack or phone dismantled), all you need to do is to brick your software as well.
If you had a software brick, make sure you make it into a full brick.
The service center will not be able to check for counter as a result.
I broke my sony xperia play keypad and samsung note 2 screen, they just give me a new set as a result.
Leonard_Ong
Usually the service people will bluff user faults did you have to pay for it?
reimina
The success of Knox will be the end of triangle away. Good luck!
