I know I'm being monitored by CCTV but I just heck care. Feels better that way.
Has anyone made their RG GP01 FB? Is your cockpit hatch loose? I thought mine is supposed to be tightly closed but it's not.
anyone used rj london gold paint before? is it based on enamel?
any recommendation for what type of paint for washing over enamel?
cos read up that acrylic over enamel is a no no..
Hi guys, any spray paint to recommend?
Tried looking for DPI branding but no luck finding it so far..
Does anyone know whether using the shipping from hlj is cheaper than those forwarding service? i might order from them soon cause their prices are really cheap
yes hlj is pretty cheap compared to other japanese online stores like hobbysearch or amiami. this is because hlj used plastic bags filled with air to cushion the product instead of paper used by amiami and hobbysearch hence lower weight and cheaper shipping. u can actually see the shipping cost for ur item just add it to cart and u can see it at the right under shipping methods
OK please help this absolute n00b out
Say I made a mistake of pressing 2 parts together without putting another crucial part in between 1st; & now I cannot separate the 2 mistaked parts
Are there any services that do separation of mistake moves? Or just LLST buy a new kit?
you can use a part separator.
some will just use sth sharp to go inbetw them and 'pry' them open but its might damage the parts.
Anyway, finally sticker-ed and topcoated the GP01.
RG is definitely the grade for the lazy Gundam fan like me![]()
