GALAXY NOTE III ACCESSORIES
Inertiaholic
thanks for the advice. A shop at plaza sing quoted me $18. Is this a reasonable price?
glass sp was like mmm...79? very scary number...
I would advise against oleophobic. I used it for my note 1 and the coating came off after some time, and then it just becomes a crazy fingerprint magnet. I've been using optics so far and its pretty good.
Bapenigo
So many people using neo hybrid
Dun feel like buying liao
Yeah. Agree. Most note 3 user have the same setup. Lol
If you pursue for something different/ unique, I would suggest to you to wait.
Jhyun
Can you recommend some? The samsung ones, the wire is too stiff as well.
That's the limitation of the cable itself. If you find it too stiff, then use the old micro usb cable since it works totally fine.
I'm not seeing too much of a difference in charging time using either cable when connected to a wall charger, so you are likely going to be fine with even a micro usb.
jctj90
$18/piece for normal spigen SPs is pretty steep imo. I got the 2pc set from p2o at burlington for $25. Glass I think 60+ iirc.
dash7869
haha true that.. cuz new device ma.. limited covers still... :)
i got bored with neo hybrid yellow so went to hoot a metal slate today...
ZhuTou!
Ya la all note3 user will look the same, juz diff colour only
I juz wanna protect the side chrome area nia
Shall wait for nice nice bumper :o
Bapenigo
Wow! You tested both of them? That's a piece of great news. Thanks
