harky
- Jan 20, 2002
the S-View function isit works?
I would advise against oleophobic. I used it for my note 1 and the coating came off after some time, and then it just becomes a crazy fingerprint magnet. I've been using optics so far and its pretty good.
So many people using neo hybrid
Dun feel like buying liao
Can you recommend some? The samsung ones, the wire is too stiff as well.
thanks for the advice. A shop at plaza sing quoted me $18. Is this a reasonable price?
glass sp was like mmm...79? very scary number...
Haha then slim armour lo!
Yeah. Agree. Most note 3 user have the same setup. Lol
If you pursue for something different/ unique, I would suggest to you to wait.
anyone bought battery? how much is the extra battery cost for original?
Kasia, 68 dollar , extra battery kit, come with charging kitand battery
bought at p2o for $49
That's the limitation of the cable itself. If you find it too stiff, then use the old micro usb cable since it works totally fine.
I'm not seeing too much of a difference in charging time using either cable when connected to a wall charger, so you are likely going to be fine with even a micro usb.
I hooted a metal slate and glas.tr today too.haha true that.. cuz new device ma.. limited covers still...
i got bored with neo hybrid yellow so went to hoot a metal slate today...
If possible, I would let my note 3 go naked.Ya la all note3 user will look the same, juz diff colour only
I juz wanna protect the side chrome area nia
Shall wait for nice nice bumper![]()
anywhere selling the original wall plug and cable?
Got answered before:
Kasia - $68 - Battery + Battery charging kit
p2o - $49 - Battery
I believe p2o is not just battery but the charging kit too as well..
I just posted it few pages back.
