Sony Smartwatch
Jhyun
Hmmm the SBH52 can remote playlist right?
Was thinking if it(SW2) would work with less smart headsets like my MDR1R-BT or Jaybird Bluebuds X in terms of remote playback.
Is there any support for Spotify remote at the moment?
arcanehacker
I don't see why it shouldn't work. Its basically controlling your phone direct. Then the phone BT change back to any headset..
Vulpix
Moderator
Moderator
Any other comments on the watch? I'm liking what I see so far other than the price.
jefefe
i'm using smartwatch with SBH52 on my Z1. Both SBH52 and SW2 are connected to the phone. i can use my SW2 to control the playlist that is playout on my SBH52. Is this wat u lkg for?
hmm but SBH52 itself already can control playlist right? .. i am still thinking is there a need to buy SW2 ..i am currently using SBH52..
anyone can sic how difference are they?
samigo
Frankly I find SBH52 very useful. It can function as a phone to make calls (from call logs), receive calls, see msgs (SMS, Whatsapp). The only con is it's alert sound is a bit soft.
zhaoshanhe
how to enable msg from whatsapp ah? need to dl a separate extension/app for it? thanks
dsclaymr
I paid for the extension. But after reading in xda forum, downloaded and installed watchit, imo the best watch app available in the market, plus, its free. Try it.
yhw22
the notification got sound? as website said that notification thru vibration.
Jhyun
Saw one last piece at IMM yesterday, but $288, no discount.
daniel_83
i reserved the last metal strap version at Mobilesquare
heng ah
