Hi
Anyone where to get SPIGEN Samsung Galaxy Note 3 Screen Protector Glass Tempered Glass at any local mobile phone shop?![]()
burlington square (beside Sim Lim Square)
Hi
Hey thanks! Do you happen to know which shop?![]()
Now even my Dad complaining that the S View Cover sucks and useless. Especially with the front flip, not closing properly after it was flipped backwards for using, flip forward to close, the elastic edges bounce back and the sleep wake function can't sleep it.
Another issue, S view functions is quite redundant, camera can be access quickly if you put the icon at lock screen, quick memo is much easier by flipping open the screen and pulling out S Pen gives the pop up circle faster. Music, lockscreen has it.
Can't reply SMS or Call people directly from the S View. So in the end the case is pretty useless, Calls answer and hanging can be done as per normal on lockscreen too...
P2oMobile?
Thanks mate!
No worries
Seems like there is no other good option other than to go naked or with Spigen's neo hybrid?
Counting down to the arrival of my device...
Anybody has an idea if the spigen ultra fit case is available locally? Thanks in advance!
so far i have tried both the original s view cover and neo hybrid... i like neo hybrid better... although it makes the device a bit bulky and heavier, but i don't mind that and overall, it looks nicer also... s view cover the flip cover must make sure it closes... if not the screen will be turned on and drain battery life (which i think happen to me)
Saw some bro recommended Capdase case too... find it quite good also (as i have use the version for Note 2 previously)... thin and light... but not much of shock protection la...
same set up as you, and similiar conclusions though i thought the screen will off after the time out anyway? i set my to 15secs..
if the s view can offer more functions i think i will use it again..
i find the s view cover abit too "fat"
Adix u have pink battery cover ar?
no... its a pink note 3...
