Singtel fibre and IPv6
too456
Didn't call singtel, but in the aztech dsl7000grv singtel admin page, the details for ipv6 support are already filled in under IP Tunnel. Didn't fill it in myself. Disabled by default though. Enabling it makes opening sites take quite long, so I disabled it again.
Arucard
I have no problem enabling it on my asus N56U. Still load as fast. Maybe you can screenshot the settings let us see
too456
Settings are the same as the ones posted a few pages before. I find opening sites like youtube, as well as play store on my phone/tablet much slower than with just ipv4.
critical888
i called them to say i wanna activate ipv6, but they say its activated by default, no need pay 10 dollar, i followed the asus rt56u configuration, ipv6 test says fail, but say my ipv6 configuration is correct
Arucard
Have you try to reboot your router? Maybe you screenshot your settings let us see
Arucard
I was thinking , that guy trying to smoke us is it , say need to go down and pay money somemore :s13:
critical888
there you go, what did i fill wrongly?
critical888
is it normal, when i off ipv6 i can get 500+mbps at singtel speed test
when i on ipv6, i only get 200mbps at singtel speed test
Arucard
On or off , I still get my speed 300Mbps , Anyway too many weird case.
I don't know is it user problem or singtel so from now on , I no comments.
jtjt00
My Singtel 200Mbps Fibre don't has the IPv6 add-on option.
Yes. You log in to Onepass and then under the fibre connection entry there is Show Details there is a list of addons. IPv6 should be there.
jtjt00
Finally, managed to get IPv6 running.
However speed test at speedtest.net is at 1/2 speed I get from IPv4.
elpibe10
SingTel's speedtest server is pretty messed up. Getting bad numbers even from my VQ line.
Use SGIX speedtest server instead.
