uh, first thing that comes to my mind: how much free space left? if <25% move your data elsewhere.
How many seconds from pressing power button to appearing desktop?
which windows version are u using?
When boot to desktop, how many processes running in the background?
Use Task Manager to check. Right click on the blank space in the Task bar and select Task Manager.
thanks bro its 88 now
Too many unwanted programs loaded into memory at start-up and this may explain the slow boot.
Use msconfig to disable unwanted programs.
Hello,
I saw people use the Run software to run the msconfig, actually what is the usage of msconfig? Can you explain it?
Thanks!![]()
Nowadays, most software such as Java, Quicktime, Adobe, etc will put their applet in the systray when system start. These applets load when windows start and continue to hoard cpu/memory resources. So use msconfig to disable them from starting at windows start.
Oh, okok. Thank you for your explanation!
Err, how to do it? Can you teach or show me the step?
