GALAXY NOTE III ACCESSORIES
Jurong640
Note 3 Extra Battery Kit. Pls Check for MADE IN KOREA for Cradle and Battery for best quality product.
was wondering if it charges the battery fast. last time i used to have Note or other universal battery charger, it takes 1 day to fully charge the battery.
How long does it take to fully charge? i noticed the output is only 450mA
insurrect
takes slightly less than 3hrs to fully charge
tjkb230
that is when the input is taking in at only 500mA --> computer USB port for example
otherwise, if use a dedicated charger, you should reach max input 2A and output 1.7A :o
Bieffe
If this device got a dongle that can double it as an external battery that will be wonderful.
lelouch91
Hi Gurus, I saw a few Neo Hybrids today at different shops. All quite different in prices. One selling only $22 the other I saw was $49. There's one @$52.90 Why like that ha? Fake ? Thanks
一分钱一分货?
$49 is the price across most seller for the genuine one although some stores are selling @ $39.
$52.90 maybe they mark up abit?
$22 too good to be true, most likely fake.
But it doesn't mean you paid $49 or $52.90 proves it not a fake too.
My SPIGEN case ship from amazon USA.
I got mine from p2o. Not sure whether is it a lighting difference but my yellow seems abit darker. ~_~
Mind sharing pictures of the plastic casing too?
Some bros said they will upload pictures of their fake neo hybrid but still no news.
Here are some examples of fake Neo Hybrid from others. Images taken from the reviews of the product for this seller on Qoo10.
Qoo10-Singapore - MP3 / Mobile / eBook - For Note 3 n9000
The Big Fugly Caps Wording that spelt NEO HYBIRID
The Green Packaging unlike mine is Silver in Colour. And the plastic cracks easily.
The rest are loose
Audiology93
一分钱一分货?
The rest are loose
I bought a fake one and it doesn't have cut out for speaker.
attapKia
I think dont use screen protector best..... That is after i put a screen protector on.....just doesnt feel as smooth....hmmmm.....its like havin sex with n without condom that kind of feeling lol.....:D
have you tried glass sp?
zXioNGz
That's because you didn't pay the premium price for premium "glass" condom, hahaha
adix_82
Is the momax glass sp better then the spigen ultra optics?
Are glass sp easy to remove?
The glass sp can be remove and reused.
Thing is.. U must exercise the correct internal power and let the Qi flow thru ur finger to gain the orchid flower fingertip(translate into Chinese) and peel off the glass.
Most of the dealer know the orchid flower fingertip skill.
virus2977
best is buy direct from spigen. spigen direct stock to Amazon USA.Buy from amazon not scare fake one.Somemore price also cheap. Now US dollars drop like siao.
一分钱一分货?
The rest are loose
downxxer
Wow, cause I'm using ultra optics now. Thinking should I change to glass sp.
