leejhong
- May 30, 2007
How should carbolic be used?Like twice/week?I am using kanebo on a daily basis now but since u all mentioned carbolic,i am a little hooked on it now.
Carbolic will make your hair a little drier as compared to Kanebo. My take on this will be using carbolic for 3-4days per week and use kanebo on other days. Depending on the activities for that week as well, of course. If you sweat more, then it makes more sense to deep cleanse to get rid of the impurities thoroughly.
I myself am using Carbolic almost everyday with alternating usage of Pote Organic Shampoo now. The only big problem that i have with Carbolic is that it doesnt lather up well so i need to get it quickly onto my head otherwise the watery form will just flow off my palms.
