GALAXY NOTE III ACCESSORIES
evershineoptical
I got the neo hybrid, should be real one cos fits very well. And i think it's quite slim fit already compared to my note 1 with that nillikin TPU case.
any recommendation for battery for note 1 ? i think my note 1 battery spoil, drains very fast every time after charging.
duckling
Do you find it difficult to remove the S Pen with the Neo Hybrid?
evershineoptical
I think it depends whether you have big or small fingers. I have small fingers and i actually find it easier to remove the S pen with the neo hybrid than without.
I see what you mean, i have to use fingernail to pull it out.
adix_82
bro, does spg or momax glass sp fit with Neo Hybrid?
Both fit with spigen. Now come down to how much u wanna pay to install in. But take into consideration should u break the glass, u have to pay for another installation and the cycle goes on..
ZhuTou!
Saw battery cover at gadgetworld $29
Got many colours, i think brand is gizzar
Not bad quite nice but never buy
Duno what colour match black phone :D
teoph04
Dropped my phone today, lucky got spigen neo hybrid to protect but my glas sp crack a little at the home button area. Heng
adix_82
K. Luckily.. The glass sp will help u to withstand. If not.. It will be ur LCD crack.. But u got to install a new one.. Unless u can leave with the crack.
teoph04
Yeah, which is why i will be seeing you tmr evening, haha. Getting the s view black cover tmr as well. If you already know who am i. haha.
PS.Hipster
it only looks nice for the white note 3. tried on the black note 3 and it sucks.
Its a hard plastic/rubber material and is a frosted..so thats why it doesnt look well with the Black note 3. For usage on the white note 3, it looks as if its naked. And overall quite slim.
nakedtoes bought it without the packaging. mine was with the packaging. he bought it at m1 shop opposite kasia mobile whereas i was recommended by a fellow forumner to get it at m1 marina square called handphone inspiration.
does your case fit perfectly? I bought mine at suntec and it does not fit perfectly at the top part. Seems like the case is a bit smaller than the phone.
kyleongwl
got my, green, on the 1st day.
Its rather good...more "leather" than Samsung
kyleongwl
Wow, cause I'm using ultra optics now. Thinking should I change to glass sp.
If u aim for higher clarity, u can change. If u are sick of paying for shatter lcd repair, u can get the glass too.
I was using the Spigen Ultra SP.
Yesterday, converted to Momax tempred glass and it is very much clearer.
As it has a cut slot at the bottom and if impacted drop on it..finished.
adix bro,
thanks for the fix up yesterday.
And the expensive model for my Xperia Ultra shows me that the $ spend is worth..
Might change my note 3 momax to the exp ones..got discount? :p
