There's only 1 type of momax in his shop, unless you are talking about the other brands like clasy or x-max.
the only blue momax i saw was for the iPhone 5S lol
Shavy, you got any Rock Quicksand series for Note 3 ?
Price difference between Clasy and Momax. $48 and $22.
Difference in thickness and material.
Clasy more towards spigen style in terms of material and technology used to make the glass.
Both have the same cutting.
Most important both Clasy and momax won't burn a hole in ur pocket.
nowadays i don't like these type of snap on.
dropped once, although protected the phone the case broke.
plus these snap on never fully protect the sides. feel very insecure lol.
so now using neo hybrid instead.
Hey anybody got link to Qoo10 that got sell genuine Note 3 USB 3.0 cable that's at least 1.5m long? Thanks
the original case inside got how many?
Seller says original. I ordered 1m cable i not sure quality cos havent received it Qoo10-Singapore - MP3 / Mobile / eBook - Original Samsung USB Charging...
this is the same link that a bro posted before (jurongxxx).. i bought 1.5M from there.. confirmed genuine...
But this reply abit...
[Re] Samsung Note 3 USB3.0 Cable 1.5M Original?
Hi,
Yes this is original Note 3 cable being remove from the phone box. You can check out my review from other customer whom had receive the item and you will get a clearer picture. Thanks!
You guys tested it out? How's the transfer speed?
Does the Class &/or Momax, do they have the round edge as compared to Spigen Glas Tr?
Wear a name tag lah....so that people can easily identify you.Recently.. Some bro who went to Burlington square were unhappy as they were quoted at $48 for momax tempered glass protector.
I was branded as unethical and a cheat for giving fake info and lie about the price.. I then realized, some of you are at the wrong place and again not surprisingly talked to another "adix82"
Pls do note, adix82 hates wearing spectacle. adix82 seldom go for toilet break. There is very little chance u won't get to see me unless I decide go eat a little snake.. Pls make sure u are speaking to the right adix82.. And last thing.. U have to be sure u are at the right place...
Thank you mod for giving me a chance to explain.
Like "BRO Adix82" or "Bro Adix82 assistant"
