- Jun 5, 2007
When does the MO start?
Hello. Started last week. Closing in midnov.
will it go through if minimum order is not met?
PMed you with my order.. Thanks..
I'm not very sure if it's really diluted, but I've tried comparing the sprays and roll-ons and both smell as strong. The spray has a base added so that it can be sprayed as the oil itself will clog the nozzle and unable to be sprayed.check with you.
the 30ml one is diluted or same as the 5/10ml one in terms of concentration?
yep, help me check then i'll decide to the the 10ml or 30ml one. thanks.
