Where to find watch deployant + installation?
bubblesz
Jedi Youngling
where can i find the clasp and leather + installation from which shop?
the deployant looks like this
jonleelk
tpmmark
wat brand of leather strap and deployant u looking for? if u like the same brand as your watch then have to go back to their service center. bt gonna be ex. if u dun mind other brands, can try gnomon watch. they have a few types of clasp and many strap to look at. go look at their online web site.
chromehead
generic deployant clasps most watch shop should have. for those original deployants or in general all parts you can expect to pay a premium
do note the length of the folding clasp itself. the one in your pic looks super long.
while it should be easier to wear and take off due to the larger lobang when unfolded, the size of the clasp look like it may not fit a small wrist(less than 6inch) properly/comfortably.
DIY install i suppose you could use a toothpick to poke the springbars if you are really scared of accidentally scratching the clasp.
bubblesz
Jedi Youngling
thanks alot! was looking for something like these. hopefully they will entertain me when i go down to thier outlet and help me install.
tpmmark
u browse their site? yup they do hav a wide range of straps there. best of luck and rem check their operating hrs before u make the trip.
