deaththeorist
- Apr 28, 2011
no no. the shop call aveda. by itself one. Marina sq got i think. j8 used to have.
redken any ol salon can have.
Checked around watsons, guardian don't have leh, probably will visit whathewants see look.
I went to dig a lil, saw this Imperial Leather, Tabac, those are for hair?
Hey, carbolic soap bars? tried googling carbolic shampoo to no avail.
I scanned through almost the entire offering from watsons and guardian already, they don't anything specific for oily scalp(or specifically for men for that matter), only came across this french brand one in guardian, didn't look too appealing tho, tried body shop, they had one for oily scalp, didn't look appealing too.
Gonna find time to visit specialize shop like whathewants, any other place to recommend me for a huge range of men's haircare product? been browsing through some online offerings too, headache uh, so many selection online!
You having permed hair or going for curly styles? Otherwise, i dont think there is a real need for you to use diffuser actually. Even i myself am not using diffuser as i don't have the required hair length to be able to utilize the usefulness of it.
Think a lot of bros got the kent brush styler to be used for blow drying.
Okay i just touched down in sg and need to stock up on spray. Where can i get osis 3 or any alternative hairsprays? Easier if around orchard
My beautybay order for the babybliss still no news...
But I go order a compatible diffuser in case my wife needs it.
Venus got sell q8 carbolic?
btw leejhong, if I use conditioner everyday, will there be a problem?
Depends on what hair style you wanna do.Hello! Pardon my newbie-ness Just wanted to consult yall experts on what's the best hair wax/clay for thick hair of 8- 12cm long that has an all-day strong hold without the use of hairspray. preferably easy to wash off too (i have skin/scalp issues) Matte or shiny look both are fine
so far i've tried the following products and am not satisfied one way or another:
1. Gatsby wild shake purple- has the ideal holding power, but difficult to wash out. kinda itchy too
2. gatsby mat grunge grey- good for texturising, but not much hold
2. dominate out of bed- dryness makes it hard to apply evenly. holding power is weak unless i apply a lot, which it then looks oddly stiff and plastic
3. obsidian dual touch wax- hardly any hold, but it does a great job of providing a healthy looking shine and is the easiest to wash off, no itch at all no matter how much i apply
Osis session is everywhere. Try far east plaza. Sure have. There's one store on level 3 that sells osis.Okay i just touched down in sg and need to stock up on spray. Where can i get osis 3 or any alternative hairsprays? Easier if around orchard
hey thanks for responding. I dont have permed hair nor am i going for curly styles. I actually want to wear a slick back/side part hair style. However Cant seem to blow dry it nicely..
which brush from kent is useful/practical for blow drying that kinda hair style?
Which model did you buy? Looking to buy one too.. probably the powerlite. How long has it been since your order?
But must use alot of clay and hair spray to let it set down. I considering though. I all the way cut chicken head, never tried this type of hairstyle before. See mirror liao not used to it.
Was referring to soap bars.
Last time I got see in Watson got sell a kaolin clay shampoo for oily scalp dunno the brand.
