Recommend budget HTPC rig
tech_oasis
Will be putting a rig together for basic surfing, office and watching streaming videos.
No games and overclocking required, will be using built in graphics card preferably HDMI.
Space is a limitation for small table so deciding between ITX or MATX. Based on what I read MATX better value for money so leaning towards getting the small MATX casing. Preferably something which fits a SSD and HD.
Please recommend.
Thanks
royfrosty
Please recommend.
Thanks
No budget?
Ark Law
Just a random suggestion off the top of my head :s13:
CPU + Mobo: soldiered i5 3337U + HM77 Gigabyte OEM - $526
RAM: Kingston 4GB 1600MHz laptop memory - $49
GPU: onboard Intel HD Graphics 4000
SSD: Crucial M4 mSATA 64GB - $112
LAN: Onboard Realtek Ethernet + included miniPCIE WiFi card
Casing: Gigabyte XM11 Mini-PC
OS: Win7 Home Premium 64-bit OEM - $110
Other: HDMI cable 1m - $5
Total: $802 / $851 (8GB RAM) / $906 (8GB RAM + 128GB SSD)
Jian19
G2010 + Asrock b75m itx ~ $164
Kingston 4gb value ram ddr3 ~ $49
Wd blue 500gb ~ $60
Adata pro 128gb ssd ~ $125
Jonsbo v2 + 300w psu ~ $99
Win 7 64 oem ~ $115
Total ~ $612 buy and DIY @ tradepac ~
MevolutionX
i3-3220 + Asrock b75m dgs ~ $211
Kingston 4gb ram ddr3 ~ $49
WD 1TB blue ~ $80
Xigmatek helios 231 ~ $48
Andyson 450w g plus ~ $45
Win 7 64 oem ~ $115
Total: $548 build at tradepac.
tech_oasis
Wd blue 500gb ~ $60
Win 7 64 oem ~ $115
This rig fits my needs and looks nice, except no space for a dvd rom
Jian19
Install OS can use USB ~ or get a external drive..
Or can change casing to CM elite 130 ~ $95 + fsp 300w psu ~ $45
tech_oasis
Thanks I may sounds like ancient but haven't installed OS from usb. Need to do some homework :)
Kiwi8
Deluxe Member
Please recommend.
Thanks
What are the dimensions of the small table that the casing must fit into?
t258jgn
Thermaltake SD101 Mini-ITX Case with 180W PSU
MSI H81I H81 Skt1150 Mini-ITX Motherboard
Asus Internal 24X DVD Writer SATA
Kingston 2x 4GB 1600 DDR3 Value Rams
Intel i3-4130 3.4GHz Dual-Core
HGST 7K1000.C 1TB 3.5" SATA3 7200rpm 32mb HDD
$600
tech_oasis
Power supply
Notice a range of power supply being recommended.
With matx i believe minimum 300w, would itx require lesser or should stick to 300w?
Thanks
royfrosty
Thanks
300w is like a bare minimum already you can find in SLS.
SyncGuy
$600
Wow... This looks like a very good HTPC rig and very affordable too!
Tempting.... Haha!
Noob here, it looks like in comparison to the Intel NUC and Zotac Mini, your recommended rig above is much better, only compromising the size right?
MoneyFace =p
Tempting.... Haha!
Just some suggestion for anyone looking for PC with similar requirements...
CPU+MB: Intel Celeron G1610 + ASRock B75M-DGS @ $117
RAM: ADATA Premier DDR3-1600 CL11 4GB @ $43
SSD: Crucial m4 64GB^ @ $50+
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE+PSU: In Win BL634 [White] + Powerman IP-S300FF7-2 300W TFX [80 Plus] @ $109
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $455
Optional:
HDD: Western Digital Blue 1TB @ $76
Buy others from Tradepac, #05-19.
^Resale Price Estimation
