bullfrog
- Jan 1, 2000
Reason why some registered new account is to avoid any issues to their default account if complications occur with their Nexus 5 orders.
Not really. Its when you first create your account, Google will assign you to the country you connected from. So if you use an exisitng account, you would have already been assigned to Singapore. You can try to change it, but google will still know you originated from SG already.
Only way around is to connect via VPN and open a new account so you are detected by google as originating from that country.
Also, as with what happened with the N4. Do not keep logging into the new account via SG IP. I read cases on XDA where google cancelled their pending order as they were not from USA.
