Head/earphones Recommendations Thread
initialtbk
earpiece recommendation.
- Your rig (LG F5, iPod Classic, Macbook)
- What type of usage (Music, podcast and occasional videos)
- File format used in your source (mp3, Spotify)
- Genre of music you listen to (Classical Crossover, Metal, Rock, Folk Rock)
- Headphone / earphone type (In-ear earphone)
- Other requirements (if any) (Not too bulky, don't need mic/vol control)
- Budget (Around $100)
My last earpiece was a Creative EP 630. Looking for something better than EP 630 with better vocal clarity and retaining the level of bass if possible. I'm open to recommendations slightly above my budget. Thank you all. :)
TeamStereo
Suspended
Can consider the Ultimate Ears 400. Personally tried it and find that it has good clarity and adequate bass. If you would prefer more bass than it, the Fischer Audio Consonance would be stronger in bass than the UE400. :)
sfoliage
- Your rig (IP 4S, DX50)
- What type of usage (Music)
- Genre of music you listen to (mandopop,kpop,classical)
- Headphone / earphone type (headphones)
- 400-500 budget
Thanks!
TeamStereo
Suspended
- 400-500 budget
Thanks!
Stretch the price range slightly you can consider Ultimate Ears 900. :)
lucashell
Teamstereo , is the UMX 30 pro available for audition ? Head down last week your friendly staff say only umx 10 available for audition
zucchini
Hi all,
i am looking for a new pair of over the ear earphones. I have used both the m6 and pl30 before, so looking for something similar and comparable. problem with both, is that one side always spoil, due to wire connection issue. both only can last like a year plus despite keeping them nicely in box after use. Any recommended brands and where to buy? also any idea where to buy m6 locally?
Your rig: ipod touch
- What type of usage music: travelling, studying
- File format used in your source: mp3
- Genre of music you listen to: pop and rock
- Headphone / earphone type: over the ear in ear
- Other requirements (if any) comfort and noise isolation, built quality
- Budget (in figures) : 50
thanks in advance!
xbearbishopx
- My rig: iPhone 5 and laptop
- Type of usage: Music and gaming
- File format: MP3
- Music - listen most genre except metal
- Headphone / earphone type: earphone
- Budget: below 150-200
TeamStereo
Suspended
What is the price now for umx 30 pro ?
Their SRP is $649. :)
Hi all,
thanks in advance!
Hi, unfortunately we do not carry Soundmagic anymore. Thus currently we do not have any over the ear IEMs available. :)
- File format: MP3
You can consider the JVC FX-T90 and the Shure SE215 Blue. If you prefer a clearer high the FX-T90 would be a better choice, if you prefer something more balanced the SE215 Blue is more suitable, personally use them for everyday use. :)
Boojibah
Hi guys,
- Your rig: Samsung Galaxy SIII, PC
- What type of usage: Music, gaming, shows
- File format used in your source: MP3
- Genre of music you listen to: Electronic, rock
- Headphone / earphone type: IEM
- Other requirements: Good noise isolation, good bass, mic and volume controls not preferred
- Budget: <100
Any recommendations? Thanks in advance!
Haeresis
Hi guys,
- Your rig: Samsung Note 2
- What type of usage: Music, shows
- Genre of music you listen to: English Pop, Chinese Acoustic
- Other requirements: Good noise isolation, good clarity in sound and maybe good bass.
- Budget: <150
harky
Hi guys,
- Your rig: headphone for pc
- What type of usage: Kpop, gaming, shows
- Genre of music you listen to: Kpop
- Headphone / earphone type: Headphone
- Other requirements: Good noise. good sound, got bass.
- Budget: <100
TeamStereo
Suspended
Hi guys,
- Budget: <100
You can consider the Fischer Audio Consonance which most people find that they have a strong bass. Also the JVC FX3X which is known for its strong bass. :)
Hi guys,
- Budget: <150
You can consider the JVC FX-T90 which is on promo now usual price $209 now $178. :)
Hi guys,
- Budget: <100
Good noise? :s13:
If you're looking for something portable do consider the Beyerdynamic DTX501p, price is slightly higher at $129. Comes with a carrying case to protect it when you to bring it around. :)
petepan1986
Hi All,
helping a friend here.
- Your rig: Samsung Note 3 and ipad
- What type of usage: Music, movie
- Genre of music you listen to: English Pop, jazz, 720p movie
- Headphone / earphone type: wireless headset
- Budget: 300-400
Thanks
bockscar
- Your rig: iPod Classic, Macbook Pro
- What type of usage: Music (Apple Lossless or FLAC)
- Genre of music you listen to: Alternative Rock
- Headphone / earphone type: earphones
- Budget: up to $500 maybe
Currently using Fischer Audio DBA-02 Mk II. I quite like this type of sound. Tried Shure SE215 but i don't like so much bass. Anything close to the DBA-02?
Thanks.
LouisLoh
Thanks.
Definitely the W4R on discount.
Westone 4R with Removable Cables
Or you can try the market place on HWZ to look for BNIB units as well if you don't want to ship it yourself.
