it helps lah.
why dun u enable it and reset yr wallpaper again
On "reduce motion" to prevent your wallpaper from zooming in or out.
I never like to restore from backup. Setup as new better for me.
I notice the default Camera app is unable to have the settings for HDR maintained across sessions. Previously on 7.0.2, I can have the HDR toggled on & this will be sustained everytime I launch the Camera.
There is another bug not sure if anyone else experiencing it. Last time while typing and I press on any area to zoom in, I can see the blue cursor. This helped a lot when I need to correct a spelling mistake, punctuation or certain words. However, now the cursor is missing every time I "zoom" in. Anyone else has this issue too?
latest 7.0.3 confirm drain more batt, cos my philips alarm clock can no longer charge it even though it's showing the charging status....
closing all apps and restarting phone yield same results...
Maybe thats true. Before latest update to 7.0.3, the batt indicator is solid... End of day still at least 50%
Now not anymore... But again someone posted that batt indicator is just indicator.. It only shows the rough amt of batt left, not actual batt...
Btw i also notice that the batt life tends to be better if i use with apple original case. If i use PS bumper, the batt drop like crazy.... Wonder if i affect the reception and thus use up more batt..
Hi, just wanna asked: i notice when i'm going to unlock my screen using fingerprint / password: there's a black glitch a while before showing home screen. Is this normal?
And I notice sometimes when I open either instagram or imessage, there's also a fast glitch but it happens once in a while
Anyone experience the same thing?
wow if this is true
apple so clever first is make all fake lighting cable can't use
and now this haha power
u mean the apple case the leather for 5s?
Yes I mean the original apple leather case![]()
Wow then I Better switch to apples 5s leather case haha
Might be only haha was going to hoot a real leather case cost $100++ haha
But 5s original leather cAse also looks good too just don't have any brand behind it haha
Actually I atil on 7.02 version
haha dunno is it me or wht... but i find batt drain better with the original leather case.
I m looking forward to next update...hopefully can fix most of the bugs and increase batt usage / efficiency
btw just to check if any one of you sometimes will get 3G connection? Sometimes while browsing internet or check email/ fb, suddenly no 4G connection..and the phone cant load anything. Worse is that it start to use up batt and drain fast....
usually i would just go another spot and on/off 4G connection again. It works for me.
Not sure if you guys encounter this...
