XiangKaPager
- Dec 21, 2012
Anybody got the US set? if the LTE works in Singapore?
US set LTE band is diff from SG. GET AU/JP set if u want LTE.
It's possible for us Lte band to be compatible. Google tends to understate all the bands. Same thing happened for nexus 7 (2013), they added band 3 in official specs after sometime. Only way to know for sure is testing it in sg.
I rather pay about $50 more to get one that confirm work D:
Yep. Just thinking if anybody who bought the US set has received and tested it in Singapore. Might get lucky.
Just thinking of anyone owns nexus 7(2013) with LTE.. Maybe this could give us a hint.
Nexus 7 from ASUS, Nexus 5 from LG. Can't really compare leh..
Point taken..opps.. Dun make me regret
Different SoC. N5 using snapdragon 800It's possible for us Lte band to be compatible. Google tends to understate all the bands. Same thing happened for nexus 7 (2013), they added band 3 in official specs after sometime. Only way to know for sure is testing it in sg.
at the most no LTE only, everything else is the same. cheaper also![]()
Got a feeling US version may also work. Den buy from jap for no reason lor. US cheaper.
Hi all,just want to check if purchase from Japan play store the voltage of the adapter if it's 100v can it be used in Singapore?
Thank you in advance.
