So when setting up N5, we can only use the gmail acct used to buy our N5?
Pls advise.
No. You can use any gmail.
Pls advise.
Pls advise.
I believe you can change the region. It's a developer's phone after all.
think they are talking about the after effects of buying devices .. you get lock-ed to either US store (if u bought there) or in this case, locked to Japan playstore.. each time u go playstore now w/o VPN u will see japanese words.. and cannot buy/install certain apps that are for Singapore only.. such as the stupid AXS Payment app, Capitastar app, and some other local apps dun let u install if u are locked to US or other stores that are not SG based.. sian![]()
any accounts also can
I thought as long as you login a gmail that is registered under SG / US, your playstore will be in English & currency will be SGD/USD?
Personally i got two gmail for playstore, one US and one SG one. can switch between both tho.!
Yes, im doing that too. US tied account cant download/buy region locked app like mcdelivery. Its a slight hassle, so a warning for those who intend to get from other play stores.
For those using vpost, got a 10% discount coupon : SGLAUNCH10
And check your promotions tab in gmail, heard the notification for parcel ready will arrive there.
SGWELCOME15 for 15% for new signups.
so far, what card is best for vpost ah?
No such thing la. As long as you log in to your phone with your sg account to, your store will be sg. If it doesn't change back, just reset the play store and it will Che k region again. It's based on account one. Not where you buy the device from oneYou mean on the phone itself, even though you have signed in using your Singapore Google account, it's still locked to Japan's region?
Just went to check the account that I used to buy a n7 2012 and n4, indeed switch to US store liao, can access without VPNmy main account became US.. and then cannot install SG apps like this.. https://play.google.com/store/apps/details?id=sg.gov.lta.mytransport
sianz
Just received SCB sms. Full sum deducted in yen~
Good luck guys.
