Note 3 - Qi Wireless charger
Jeremy1
Just like to ask, do u need to remove the phone case like Neo Hybrid in order to charge ?
Thanks.
ekramhossain
I am using QI WIRELESS CHARGER Receiver FOR SAMSUNG GALAXY NOTE 3. It's cool. I think I got original one.
Jhyun
Just jumped on the bandwagon... but I'm probably gonna sell it away. Generates too much heat for my liking.
sinmarket
I am note 3 user.
Used to use the oem wireless charger for note 3 and other phone previously.
It is cool to have wireless charging for the phone.
Only set back, Qi wireless charging has limitation on the current output.
Nowadays device are power hungry. Battery capacity are getting bigger and we need charger and phone or battery that can accept high input current/output current for fast charging.
Qi technology would not sell unless they can do 1.5A charging.
if you do not mind the slow charging such gadget are cool to have.
cy
Hi, any bro here using wireless charging with Otterbox Defender case? Cos Bro Adix said might not work cos e case quite thick. Any bro can provide infor? Thanks
wilflare
anyone knows whether wireless charging will work with the spigen neohybrid case? or is the case too thick?
KlooLess
I'm using original Samsung charger base with a Nillkin stick-on wireless charging receiver, no problems charging through the Spigen Note3 Neo Hybrid case.
