old All in one broken
vofzxy
hi all
i need some advice here,
i have a old all in one HP all in one TouchSmart 60-1036
HP Support document - HP Support Center
Only $600 HP touchsmart 600-1036 23"1080p touchscreen All-in-one only 1month warranty
mine is broken, the VR link is NOT MINE !
erm it jsut wont start anymore, it hangs at the "windows starting screen"
i tried changing the hdd, can it won't even get to the recovery process.
i put back the old HDD and the it still gets stuck at the "windows starting" screen
i can't find the receipt anymore, its about 4-5 years old
what can i do with it?
i remember buying it from a PC show at expo
i don't know/remember who the vendor is or who services HP tech support
i believe it is a MOBO issue
im not sure if i can just bring it to any SLS service shop because of the spare parts issue.
can i get some advice please?
i would REALLY like to just fix it up again, THEN dump it off in working condition.
THANKS in advance
yusoffb01
i dont think any issue with it.
find a copy of windows and burn to usb or dvd then reinstall windows using your product key
vofzxy
i already tried that
it hangs on the windows starting stage.
it just wont run lol
yusoffb01
did u try reinstall windows on seperate hdd?
faulty ram may also prevent u from booting poperly
vofzxy
hi all.
back again
been busy with work so far.
urm, actually yea i tired to install on a new HDD, but it won't work
i will act on the RAM issue. !
PS, i dropped a screw inside the computer. :(
thanks
royfrosty
hi all
THANKS in advance
Check the ram. Run memtest
vofzxy
hi guys, thanks for all the advice
my specs are:
Your TouchSmart computer supports memory with the following specifications:
Dual channel memory architecture
Two DDR3 SO-DIMM (200-pin) sockets
Supported SO-DIMM types:
PC3-10600 (DDR3-1333 MHz)
Non-ECC memory only, unbuffered
Supports 4GB DDR3 SO-DIMMs
Supports up to 4GB RAM on 32-bit systems or 8GB RAM on 64-bit systems
Approximately 3.2 GB is addressable on 32-bit operating systems
i will have to go to SLS and find some 1333 RAM, a few HDB mall shops have told me that 1333 is almost phased out already :/
dingy com.
vofzxy
hi guys
thanks for all the advice.
but i have given up,
i took out 1 pc of ram and how the comp starts, however
i have issues trying to restore it as the installation keeps hanging
so yea, im gonna try a repair shop.
thanks guys
vofzxy
hi guys,
i have got it fixed finally
anyone knows if PC shops buy it for scrap parts?
thanks
