Gaming Rig, please advise
GetaBlue
Hi, been a while since build com, after reading abit please advise on the following, Thanks - built to play BF4
1 - Fractal Design Arc Midi ~ $129 or cm 690 iii
2 - MSI B85 G43 Gaming + 4570 = $417
3 - Gigabyte r9 28XOC 3gb ~ $449
4 - 650w Modular PSU - please advise ($120 to 160)
5 - Crucial M500 240gb ~ $240
Total - $1385
Old Parts
1 - Kingston Valueram 2 x 2GB - enough for BF4?
2 - WD 1TB Green
3 - KB, Mouse, Speakers, Monitor, OS
I know sure got comment on the MOBO,
MSI B85M G43 vs G43 Gaming additional $40 more
PSU, I need one modular one. 650W should be enuff bah, overall com is not in air con room so need parts to be running on low heat.
Casing I like the simple design of the Fractal, spec says can fit gfx up to 290mm, Gbyte 280 card is 285 mm right? so shld be able to fit snugly
So guys, wada you think???
Jian19
i5-4570 + Msi b85m g43 ~ $356
CM hyper 212 x ~ $69
Corsair vengeance 2 x 4gb 1600mhz ~ $118
Crucial m500 240gb ~ $240
Gigabyte 280x ~ $449
Seasonic G series 650w ~ $145
Corsair 350d ~ 140
Total ~ $1517 buy and DIY @ tradepac ask for discount ~
Bf 4 need at least 8gb ram ~
royfrosty
You want the B85 G43 Gaming because of the Red theme is it?
Cause without it it is slightly cheaper.
Ram need to up. 4gb is will be a peak when BF4 is running in background.
The cheapest is Kingston Value Ram 8gb 1600mhz ~ $93
If you want with the spreader and dual channel type
Kingston HyperX Genesis 2x4gb 1600mhz ~ $99
Get the Superflower HX600 600W 80+ Gold ~ $109 ----> some shop got promo.
Go for fractal desing for simple build
GetaBlue
ya, MSI gaming mobo because of the red theme . but if compare side by side the non gaming board have just alittle better spec, have display port.
going for the fractal casing cause of the simple design, or cm690 for functional.
see that have to up ram...another 100 gone haizzz...
Thanks for the advise given. appreciate it
GetaBlue
Final Design
1 - Fractal Design Arc Midi ~ $139 (PCT)
(WxHxD): 230x460x515mm
Graphics cards up to 290mm in length with the top HDD cage installed
2 - MSI B85 G43 Gaming + 4570 = $393 (T.pac), $417 (PCT)
3 - Noctua NH-U9B - $85 (T.Pac)
4 - MSI R9 280X GAMING 3G - $479 (PCT), $452 (mynextcom)
5 - Corsair Vengeance 1600MHz 8GB(2x4GB) - $118 (PCT)
6 - Superflower HX600 600W 80+ Gold - $109 (??)
7 - Crucial m500 240gb ~ $255 (PCT)
TOTAL = $1551
What you guys think, Trade pac pricelist many items show offer only, no price.
boygenius
Final Design
TOTAL = $1551
You can get your GPU+PSU from mynextcom. Having promotion.
I got mine there as well. $30 save can put somewhere else :D
Superflower HX-600 Gold Modular + MSI R9 280X Gaming 3G $529
royfrosty
Final Design
1 - Fractal Design Arc Midi ~ $139 (PCT) $129 TP
4 - MSI R9 280X twin frozr 3gb + superflower hx600 600w 80 + gold efficiency ~ $ 529 (mynextcom)
5 - Corsair Vengeance 1600MHz 8GB(2x4GB) - $118 (PCT) $115 TP
7 - Crucial m500 240gb ~ $255 (PCT) $249 TP
TOTAL = $1551
Eddited for you already.
Pretty much good to go.
