He never mention his hair thick or thin ma, wax is good, but if i have a choice, i wont use wax to do a comb back or side part unless bo bian, i will certainly go pomade
Ya lor. So gave him 2 choices of either wax or pomade.
Depends on what kind of hair texture he have lo
For me I prefer the look of using heavy wax to do it because Asian hair, if use wax, it will appear to be thicker. Pomade will actually separate hair and create spaces, mainly because it's water based. Just imagine your hair is wet and u come back with a comb. Haha try it and you know what I mean.
And pomade is usually high shine. The only low shine is imperial pomade paste.
it boils down to how the person hair texture is like. If thin and fine, don't use pomade. If super thick and soft, use pomade, will be better.
Soft as in your hair is able "listen" to you, going whichever you want it to go. Like Rasmus hair or coollikeabird hair. Both on YouTube. Can go see how soft is their hair. Lol jin song to have that kind of hair.
