If first time polishing you will need more base layers of wax before you can
start spit polishing. I start with 6 layers for new shoes.
You need time for the layers of wax to dry before you start to apply another layer. Or else subsequently layers will remove the previous layers.
You were rubbing a wet cloth onto the wax layers and rubbing them off instead of adding on layers of wax with the aid of water to help smooth the wax layers.
Ah... I see.... I had a feeling that was the case after another round of testing last night.
So how long should I wait for the wax to dry? And how thick should the layers be?
Thanks!
