[Mac 101] Ask your questions here!
mgumpy
hi guru, i am new to mac os. how to i cut and paste files in the finder window? the cut and paste command seems to be disabled. e.g. i use command x and command v but has no effect.
i tried using Command C and Command Option V for cut and paste and it works. :)
eagleboy
Hi, i m getting rMBP 256gb and planning to put window7, can advise me how many gb should i set aside for win7? Thanks:)
iCubes
Dude..you need to tell people what you gonna use Windows for before others can advise you properly.
simonscs
I just got my rmbp 256gb model. How do i backup the mails on my mba? I did a export on the mailbox but it doesn't work. I have a time machine backup but wish to only transfer certain files over to the rmbp.
chehjin
why don't you use time machine and move everything, then proceed to remove whatever you don't need after the whole machine is migrated. Isn't this much easier?
knightcover
hi!
my 2013 MBA (on OSX Mavericks) often loses wifi connection after waking up from sleep.
any solutions?
already set my router to WPA2, as per suggestions on Apple forums, but to no avail.
chehjin
hi!
any solutions?
need more details. when you say lose connection, is dropped but eventually recover or like banned for life?
what router brand and model?
PetPet
Moderator
Moderator
hi!
any solutions?
Only run into this issue when my network is a hidden network.
simonscs
I have another problem now. I tried to factory restore my MBA through Internet recovery mode and it doesn't work. Google and found that due to singnet proxy problems. Anyone have a workaround for it?
knightcover
some lousy TP-link router as I am on overseas exchange now,
for example: when i wake it up from sleep, the Wifi signal bar will be empty, and when i click on it, it sometimes shows that I am connected to the network. otherwise i am completely dropped from the network altogether.
i normally have to restart wifi for it to work again.
mine is not wor. :s11:
