Hi people! I am doing a pre-order for Fudge Ends Hair Serum. The main purpose is to test the market response for hair serum to be brought in for the SG community. It can be used on towel-dried hair or dry hair and all it takes is just a small dab to work through the hair. A little goes a long way and you dun have to wash it off after that.
Basically, it can help to repair your split ends and achieve silky hair ends. Also, it comes with a very pleasant smell and helps to effectively replenish the lost proteins in the hair. All in all, its convenient and anyone, both males and females, of any hair type can use it actually. Hair care is the key to having good hair.
As usual, if you are interested, can either pm or text me. Cheers!
Product Name: Fudge Ends Miracle Smoothing Treatment 50ml
Price: $21.90 (w complimentary normal postage)
Pre-order Price: $19.90 (w complimentary normal postage) - PreOrder will end on 2nd December 2013
ETA: Mid December (before X'Mas)
