Ijjit!!! Basket... Kena smoke...
Yes it's true. Just in case you missed my YouTube link.
Bro, you using sony bravia 32 W674A TV? Are you using the build in DVB-T2 to get the hd channels?
Well they are still on trial, so if it's about the same as the previous DVB-T trial, the signals are normally only on either during the day, or from 6pm to 11pm.
Yup!! The test channels very clear.. Later got time I post from my HD media files to compare ...
Folks which antennas r u using again? Cannot use the hdb aerial antenna?
I have an LG DvB-T2 build in TV. I tried auto tuning at 7am just now.Under DTV auto tuning, it doesnt detect any digital channel. Any idea why?
i just connect from the wall scv cable to tv lah. Is that correct?You got connect coaxial to over the air antenna or the windows grill like me?
Alamak. Then this dvb-t2 channels come from which source? I thought in flats, only got two source, scv wall cable and rooftop antenna cable?The wall SCV cable antenna only has DVB-C signals and no DVB-T2 signals. If your DVB-T2 TV doesn't support DVB-C then it can't receive the channels.
So for my case, shouldnt then the tv detect automatically even though the scv cable is connected to the tv?
i dnt see any mentioning of dvb-c in the online product page of my lg 47la690t.just dvb-t2. Can help me check and confirm?but it should support dvb-c too rite since i can watch scv wall cable channels now.So u have not answered the question. Does your TV support the tuning of DVB-C channels?
i dnt see any mentioning of dvb-c in the online product page of my lg 42la690t.just dvb-t2. Can help me check and confirm?
okay.but how come i can watch the scv wall cable channels which u say are dvb-c? So how is my tv able to detect T2?Only DVB-T2.
