Want die lesser? Want kill more?
Learn to look at mini map most of the time
It reveals anyone who fires or are moving under beacon unless they are using the shadow field upgrade kit, then they can only be detected when they sprint
or people that got spotted
Learn to listen to footstep
You can easily hear someone running around or towards you when you're playing commando style where there's only you or your squad around you
If there is no teammate from where the sound came from, it's the enemy
so get ready or you can always go hunt him down if he is running away from your area
then you can easily backstab him
Learn to see where bullet comes from
You can see a bright yellowish orange? line when shots are fired
And the sound of shots fired gets louder as they gets nearer
You DO NOT want to come out in a narrow path when there's a heavy cross fire
you'll almost instantly die
And when there's only you and the opponent
You can always "bait" him by hiding and coming out repeatedly until his gun got no ammo then u rush in and knife him or spray in his face (DOES NOT WORK IF HE IS USING LMG/SHOTGUN)
most people don't use their pistol or use them too late~
If you're pajiao like me, can't see **** clearly
spam Q everywhere u go/look
high chance that you'll spot someone that you can't even see
It also helps your team to see the enemy and you get points for it...
