super budget rig
Hua_Hui
Hi guys help out on budget rig for web surfing and youtube purposes
looking to spend below $400 (exclude peripherals and casing)
Asus H61M + G2030 3.0ghz - 169
Kingston CL9 4gb - 52
500GB BLUE - 67
Samsung ODD - 24
AntecNeo 520w - 85
Total $397 at Fuwell
what do you think? on a side note, does h61 chipset support the G series processor?
MoneyFace =p
If you don't store any videos locally on the hard drive, why not get an Android box?
LesterQ
Web surfing and YouTube can omit the odd...
H61 supports less USB and Sata port I think...
Socket compatibility... As long as both 1150 it's fine. For Haswell..
royfrosty
500GB BLUE - 67
Samsung ODD - 24
AntecNeo 520w - 85
$400 can do better than that. And even add a chassis
Asrock B75M DGS + G2130 ~ $145
Adata 4gb 1600mhz RAM ~ $43
Hitachi Deskstar 500gb ~ $58
Samsung ODD ~ $21
HEC 300w True Power ~ $35
Still got $100 for a chassis. Might be able to get a 1tb HDD and up to i3 even though you might not need it.
Buy at tradepac. DIY
Hua_Hui
what's an android box?
would like to have at least a pc for my mum to use
noted on 1150. 1155 cannot?
what do u mean by omit the odd.
Samsung ODD ~ $21
quite a big differential in price (~25%)
think cos I chose Fuwell.
well noted, thanks.
cheapset too low, watch youtube HD will lag one leh. think you should get i3 min.
really bro? with current technology I would imagine even the lowest end of the spectrum will be more than enough to handle playing videos.
Rock-kun
Confirm can..
Intel iGPU nowadays is overkill for basic computing and entertainment.
Want to go even cheaper can try dropping Intel and choose an AMD APU. iGPU has better performance than Intel but CPU much weaker (still more than enough for day-to-day computing) and system eats more power.
royfrosty
i3 totally overkill.
The current lowest end cpu is enough for movie playbacks and youtube lah.
Tested ACER chromebook with celeron also. Still can play smoothly.
On desktop celeron or Pentium? nah i dont think it will be any issues at all.
Jian19
G3220 + Asrock h81m dgs ~ $151
Adata 4gb ddr3 ~ $43
Wd blue 1tb ~ $78
Samsung oem drive ~ $21
CM 311 + fsp hexa 500 ~ $105
$398 buy and DIY @ tradepac ask for discount
LesterQ
G2030 is Haswell on socket 1150
Omit odd meaning if you don't use the dvd drive don't buy it... Waste of money. Haha
