GALAXY NOTE III ACCESSORIES
Akai Ryu
scevtic
Thinking of getting the Trident cyclops. Smaller than the Kraken and its actually slimmer and lighter than the Aegis! Its impossible to find a decent review though... Anyone using this and know where and how much they are in Sg?
Akai Ryu
6:15
Akai Ryu
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
222EC83A52AF004925AF3D
2224A13A52AF004A29477C
241C753A52AF004F2CA05A
2420013A52AF00502D63C6
263B413752AF00533CF8A3
google translated:
Fast charging USB cable if you're looking for a smartphone 2X Faster USB Charging Cable
Use Android or iPhone smartphone battery should one time who had suffered because you'll remember.
I usually phone calls or instant messaging, music / video viewing on smart phones, etc. I'd like to use a lot of leverage. To do this, use your smartphone to see the lack of need to charge the battery every time because it seems neukkigon inconvenience.
But feel always charge a smartphone battery discharges faster and slower real!
When the USB cable is recommended that you do this'm. Bench just a soft launch in the fast-charge USB Cable 2X Faster USB charging cable.
Meanwhile, PC or notebook or charge the smartphone from moving vehicles to 500mA to charge low power very long time, I was featured on.
But 2X Faster USB charging cable to charge the 2000mA to increase the movement of the notebook, as well as a PC or a car that can be charged quickly in benefits.
2X Faster USB Charging Cable only charge rate is simply not fast cable.
Adopt a slide switch and USB for charging as needed can be selected and used.
Smart cable for charging! 2X Faster SPEC
- SDP mode using the slide switch / DCP mode selectable
SDP: Data communications can be / 500mA charge
DCP: Data Communication not / 2000mA charge
-lamp: a generic USB Mode (Off) / high speed mode (yellow)
- Built-in over-current protection
-length : one thousand mm X 36 millimeters
- Type: Micro USB 5 pin
-supported devices: Android smartphones, Apple smartphones, Windows 8 smartphones, cameras, smart watches, portable speakers, etc.
Let's take a look at the connections? It connects to your PC or laptop USB is the same as a regular USB connection on the other side of smartphones and the USB cable and some other part of the general appearance.
Why are some long side of the slide switch is located there and why l'. slide switch allows you to easily switch the DSP and DCP mode can
The SDP, DCP mode is, SDP is a PC or laptop and the phone can communicate with each other Data are possible to 500mA charging, while a little slow DCP Data communication is not a 2000mA rapid charge but says the possible modes.
As soon as the cable connected to the PC LED lamp lights.
This example came to light orange lamp is available for DCP Mode that tells rapid charging, SDP mode, slide the switch to operate the light will turn off after replacing the lamp.
This time, for rapid charging mode once connected boatneundeyo DCP.
In general, the charge on your PC when connecting the USB cable to the charging seems almost seemed slowly charging is finished, while the smart cable for charging 2X Faster charging adapter connected to the case as if using a dedicated fast charging can feel it.
No. In fact, a little over 5% of the smartphone's battery is charged from the time left before the boatneundeyo once. Buffer has been around for about 3 hours.
IPhone cable with Micro USB type that you customized user who'll be disappointed. If only the cable adapter (sold separately), as well as the iPhone that iPad can be charged up to easily.
Office or home, schools, libraries, etc., as well as a vehicle to move data from a variety of places, or when you need to quickly charge!
Now, smart cable for charging! Why not look at once using the 2X Faster?
Easily switch between the default mode! Rapid charging for fast data can be transferred to 2X Faster USB Cable! I would recommend it. ^ ^;
http://ittong.kr/category
