leejhong
- May 30, 2007
the os sss imho should not be used excessively with permed hair ...os sss dries up the hair fast on top of the permed hair ( permed hair texture is aready quite dryed up , thats where hair serum is needed haha) If you use a wax ( most wax imo is dry ) on top of it , then good luck.
ang mo hair texture is different from asian ( ang mo hair being softer , and asian being thick and rough ) , so do use the os sss adequately.
Once you permed the hair, u dont have to use too much of SSS actually. Reduce the usage by about 50% and you should achieve even greater volume with it. Independently, permed hair alone already gives you more volume already.
