The Spectacles Thread.
kyxeros
Bros here i got a problem.. my current perm specs that i bought from jb a couple months back nw present me a problem of slipping off my face (+my face naturally oily) and now that i closely look right i notice that i got GAO DI ear... slanting downwards my right eye... worst still is nikon lenses @ over 200++ :mad:
Thinking of getting a replacement frame or all new glasses... no idea what to go for cos my face shape very guai one... those not afraid to see my face go this link.. imgur.com/VQaUuyQ
Pls do some recommendations for me thx~!! Budget about 200~300 max ba
blurryy
Where to find widest collection of Swissflex frames. What are the alternatives for light weight frames. I am looking for rimless frame
jayz89
past by owndays ytd.......looks not bad leh.
the frames quite light......anyone got try??
am wearing it right now. very light, cost me $178, only took 20min to get the spec.
much better than my givenchy spec. :(:(
:s12::s12::s12:
VodkaPear
Hi,
I m interested in getting ray ban specs.
went to a few shop but their choices not a lot.
Any place that can recommend me, with a lot of rayben specs design and price is gd.
gd if their service aso gd. LOL
d3n
Hi,
I m interested in getting rayben specs.
got rayben this brand meh? :eek:
Nakedtoes
Can try bugis parco.. Third floor.. Forget shop name but few days back I pass by.. They got road show on ground floor. 198 for ray ban frames with lenses..
Seannie
JB tends to promote nikon lenses. Which place u went to?
Oily face cant avoid cos sg too humid. You can only keep cleaning your nose & ear area. Either with facewash, gatsby oil removal facial tissue or simply using wet towel wipe to avoid skin becoming too dry.
Spec sure slip even with asian fit. A bit is ok. If too much maybe fitting don suit u. Can savage by adkjng optician adjust for u. U kip buying cheap spec wont help yur problem. And ear imbalance everybody has it. If it bothers u then got to adjust the spec arm one up one down. For me i dont like it so i dont bother abt the imbalance. Its individual preference. Good luck.
gerald27
I noticed some of us purchased frames online ....
so are there some recommended places to go and make/get your prescribed lenses with your online purchased frames?:D
ahboy82
do u want to buy mine swissflex frame?
want to let go cheap
PinkyAndTheBrain
Hey guys, can any of u guys help me out here. I'm wondering which kind of aviators would suit a more round-ish oval face?
WhiteFox
Just collected my new specs.
Rayban Frame $240
Crizal UV Lens 1.56 $140
He gave me $100 discount, so end up paid $280. Ok price or tio robert liao? :s34:
jonleelk
Bros looking for lightweight specs but want to try something different from IC Berlin / ByWP, can try this new brand Markus-T.
Glasses
The lightest asian-fit specs I have worn so far.
