[HELP] MSI B85-G43 Gaming
xtwis7
I know the above mobo is quite popular among many builds recently.
Anybody facing issues running Windows 8.1, in particular the Killer LAN driver because it seems to be conflicting with my friend's entire rig causing some boot issues?
TIA!
hengheng220
bro bsod right? i using the same board they keep bsod when the download speed exceed 10mb
xtwis7
Mine is BSOD upon every cold boot. Then need to restart in order to go to Windows. But once in Windows, it's stable but the dump files indicate it's the killer network manager that's causing the error.
hengheng220
hmmm mine not during every cold boot but bro you try go download the latest driver for killer ethernet. Cause i install liao never encounter bsod after that till now
xtwis7
I did but still got the same error. Are you on Win 8.1? And just nice Killer is migrating to Qualcomm site, really pek chek troubleshooting man.
Kince86
Sounds like a good idea to stay away from 8.1 >,<
Since this is one of the MB im looking at, are all of you having problems on win 8.1?
Personally i dont plan on going 8.1 since BnS CN doesnt work well in 8.1 but now im worried of this will cause problems with win 8 too
hengheng220
yepp leh but i dont have that problem. why not you try use a wireless adapter to test instead of the ethernet port. cause that port people say alot problem with the driver
hengheng220
I got both 8 and 8.1 still running fine on both leh not much problem
abcboy25
TIA!
Using win 8.1
Mine is after d/l 2 games,my mouse hang and it pop out and say something like network got problem.After i restart so far so good.
Kince86
Frm my 5mins dig into google, seems like quite a few have problems with the killer Ethernet drivers causing crashes in both windows 8 and 8.1
Feels like a deal breaker. I was attracted to this killer ethernet thing since i multitask often so the idea of optimising the game connection over other apps was sweet.
We need more input from users of this board+win 8/8.1 combo
hengheng220
Idk about ts leh but after i reinstall the new driver which is updated a few days back everything run swee swee no more bsod liao
leongws
not sure if similar but im using H87-g43 gaming with windows 8.1 for 2 months now and so far nothing like what u said has happen before
xtwis7
Really didn't expect such an essential component to face these kind of buggy issues. Probably not msi fault but killer ever since bought by Qualcomm.
Kince86
Well most of those forum posts was in septembrr. Anything could have happened between then and now and those OP just dint bother to update that they no longer have problems
hengheng220
Download from msi site not the forum site leh
hengheng220
I read some of the Windows forums and this came up as one possible solution. Will try it out first. Cause with or without the killer driver, the bsod still comes back upon every cold boot.
If possible take a picture of it
xtwis7
Okay. Will record the video of the booting issue tonight after trying out the standalone driver. Thanks hengheng.
