computer cannot be switched on
saysuzu
could it be casing power button spoilt or PSU spoilt? or perhaps motherboard?
sorry, i don't have either parts to replace
wtfwfs
Plug to wallplug.
switch on psu
Did u see a green led on ur mobo
That indicates power.
if no have.
Psu might uplorry.
Well thats what happened to me after like 12days of having my diy pc.
Psu uplorry.
went back shop 1 for 1. I brought my rig on mrt.... sibei chor
saysuzu
ok, can't see green led on my motherboard, think my PSU uplorry
any idea where to RMA for seasonic PSU?
bought it like last year so don't think can 1 for 1 at the shop ba
teddy1994
Plug to wallplug.
switch on psu
if no have.
Psu might uplorry.
Psu uplorry.
Isn't it better to just take out all the power cables from your mobo and bring psu there? =/ at most just 30min to plug out and another 30 min to plug in, without having to carry heavy rig~
Normally PSU should have quite long warranty one. Go back to the shop you bought ur PSU from??
wtfwfs
Got thread on forum show brands distributors
wtfwfs
Lol... brought it back to let the tech test all my parts..
saysuzu
can meh? cause tomorrow saturday so service center might not be open or something
saysuzu
anyway, just to confirm
Alev Tav Technologies Pte Ltd
Burlington Square #01-37
Scyter/Verdium/Termalright/silverstone/seasonic
http://www.alevtav.com/
Buses to there:As aboved same as sim lim sq.
is it the correct shop? called the guy just now, say the seasonic RMA service center is at ang mo kio
Lethal
RMA Seasonic PSU at AMK, Techplace 1. Not open on sat.
When u power ur CPU, no fans are running at all?
saysuzu
nope, not even any light got on, not sure my motherboard got LED light in the first place or not
i doubt my PSU has any LED in the first place though
my specs on the right btw
Lethal
If no fans are moving, no led light up at all (those casing fans/cpu fans/LED fans/power button)
Means ur PSU is faulty. U can take it out from ur rig first and just bring along ur PSU. The tech guys over at Corbell will test and replaced it for u.
Not all mobo have LED light on them, asrock b75 pro3-m do not have too
saysuzu
ok thanks, have to wait till monday for their service center to be opened
anyway, how long will the replacement takes? few weeks??
thegamer1907
usually if newer model got ready stock will 1-1 on the spot if tested faulty, else take 6 weeks or more.
best to ask corbell directly.
gs
Hi...if u want u can bring it down to my place tml at my humble corner..can test for u on the spot..and if really psu faulty can loan u a psu and help u send in the psu for rma..
saysuzu
hi, check your pm, thanks :D
