Head/earphones Recommendations Thread
devilrazor
- Your rig: Note 2
- What type of usage : Music
- File format used in your source: mp3 320kbps
- Genre of music you listen to: Pop, Bass
- Headphone / earphone type: In-earphone
- Other requirements: Without mic, volume control. flat wires preferred
- Currently using: ATH-CKS77
- Budget: Less than $100
Was looking at:
J22
UE400
A-JAYS TWO
A-JAYS THREE
Would like to have the same deep bass and clarity effect as the ATH-CKS77.. but the ATH-CKS77 didnt serve me well..
after one year all the end points of the cable start to wear off.. so i am considering flat cable
this time
TeamStereo
Suspended
- Your rig :computer with built in soundcard
- What type of usage : abit of gaming and fifa
- File format used in your source :mp3
- Genre of music you listen to some classical and kpop
- Headphone / earphone type closed or circumural
- Other requirements: comfortable? as i have a big head
- Budget:below $120
You can try out the Sennheiser HD429, personally felt that it is light and with a light clamping force it is quite comfortable also. For comparison you can compare it with the Audio Technica WS55X. For gaming wise would prefer the Sennheiser. :)
- Your rig: Note 2
Was looking at:
J22
UE400
A-JAYS TWO
A-JAYS THREE
this time
Actually even with flat wires, the earphones will still spoil easily if they are not taken care properly. :)
kurenai_19
Your rig - FiiO X3
What type of usage - Music
File format used in your source - Mostly mp3 & flac
Genre of music you listen to - KPop, Hip Hop, Heavy Metal, Rock, Trance
Headphone / earphone type - Over-ear headphones
Other requirements (if any)
Budget - $200 & below
Currently own a Ntune by Monster but find it too small for my ears. The ear phones are pressing against my ears at a very uncomfortable position. Tried the ATH-M50 and quite like it but need more recommendations so as to compare before making final decision.
TeamStereo
Suspended
Your rig - FiiO X3
You can consider the Skullcandy Aviator also, personally find it more comfortable than the Monster N-Tune. If you're looking for a more balanced sound signature then the M50 would be one of the best choice. :)
Ultrasofty
Does anyone if there is any shops selling comply ear foams with L sizes? seems like everywhere i went to only sell them in M sizes. I using shure 215 now.
ZenTape
Hi, I'm looking for a pair of earpiece for my little sister..*This will be the 4th pair Im buying her in 2years.. Since she either lose or spoil it.. Previously bought her m50 also lost.. Freaking hell..
So this time I'm only going for a earpiece with a budget of $50.
Only thing I'm looking for is decent Isolation.. Of cos with e budget, I understand I get what I pay.. But please kindly recommend what suit my needs this time. Thank you.
hopedec
Finally. I was just wanting to post a recommendation about earphones.
I was anxious about my earphones for their qualities. Don't know why, none of my earphones has lived long for half year.
TeamStereo
Suspended
Would like to thank Stereo today for the good service provided ! not afraid to give your personal opinion as well, which i like lol.. btw just curious and wonder why you pair im04 with the ifi amp because there doesnt seem to make much diff even after plugging in. just my 2 cents :D
http://forums.hardwarezone.com.sg/82778646-post5925.html
Congratz on your new hoot! We are sure you will be spending lots of time enjoying them. On the subject if headphone amps/Dacs improves sound quality is quite dependent on individual as the difference can be rather subtle at times. Especially when if one is unfamiliar with the sound signature of the products tested, it might take quite a while to hear the differences. The quality and type of music used for auditioning and very active listening will affect your impression as well.
TeamStereo
Suspended
For your little sister, check out these 3 value for money models under $50.
1)Audio Technica ATH-CK323
2) JVC-FX101R
3) Moshi Mythro
JungSooYeon
- Your rig:Iphone 5S
- What type of usage:Music
- File format used in your source:Mp3
- Genre of music you listen to:Vocal-Based
- Headphone / earphone type:IEM
- Remarks: Previously i used Denon ATH-C710 before 1 side died on me, personally i liked it very much.
- Budget:$150 and below
ghost_83
A few you can consider, mainly the Shure SRH240 and the Sennheiser HD205. If they are too bulky for your liking, you can consider the Audio Technica WS33X which would be slightly smaller. :)
Thanks Stereo for the recommendation.
I auditioned the WS33X and the WS55X today. The WS55X has a better bass and tighter (I can't find a better word for it) at the hi-end than the 33. Guess 15mm in the driver diameter really makes that much a difference.
But sadly, the 55 is a little over budget so went the 33 instead. Nevertheless, still a good buy @ under $100.
~Ghost
Elpistolero
Does anyone know where i can get new iem cables for my shure se215 cuz i dont like the stock cable as its quite heavy
TeamStereo
Suspended
~Ghost
GXGX on your new hoot. If there's any more help you would need do feel free to ask. :)
pinkpan2000
Hi Stereo, i need a few recommendations...
Your rig - Samsung S4
What type of usage - Music, both chinese and english songs
Genre of music you listen to - KPop, chinese pop, english pop
Headphone / earphone type - in-ear earphones
Other requirements (if any)- with mic and works with samsung
Budget - $250 & below
thanks for any help
TeamStereo
Suspended
thanks for any help
You can give a try on the Soul by Ludacris SL99S Samsung, A-Jays 5 and Monster Diesel In-ears. Personally will prefer the Diesel, we have demo for them at our outlets do feel free to drop by and give them a try. :)
TeamStereo
Suspended
Perhaps you can give the Audio Technica CKS99 a try. Many actually compare it to the Denon C710. :)
cool.. can PM price?
thanks
You can find the prices from the hyperlink on the previous reply. :)
slloyd
Hi Stereo, i need a few recommendations for a new piece
Genre of music you listen to - Alt Rock, Indie Rock
Headphone / earphone type - IEM
Previous earphones -Have been using Klipsch S4 and S4 II. Just lost my S4 II during my business trip
Budget - $150 & below
thanks in advance
TeamStereo
Suspended
thanks in advance
You can consider the Audio Technica CKS77X and CKX9. Not sure what would be your sound preference but you can drop by our outlets and give them a try and our colleagues will be able to help you find a suitable pair. :)
