andr3wyong
- Mar 5, 2012
Nah, I just sleep at random times of the day
Can anyone else with FreedomVPN do a quick test for me??
Can you see if this website works?
HBO GO
I haven't been able to access it for 3 days now.
Either on the web, iPad, appleTV or iPhone..
Worked perfectly before that.
Have been trying to work it out with Tech Support but no luck so far..
All other US sites under Freedom VPN are working ok.. i.e.: Netflix, Hulu etc etc
HBO GO
Thanks bro..
Anyone else??
Yes, it doesn't seem to be working.
The HBO GO site is working fine (if accessed via VPN) so the problem should be related to VQ.
Thanks for testing..
You have Freedom VPN as well right?
Yep.. Just did the same test. Working 100% fine with a VPN.
As soon as I turn off the VPN and go back to ViewQwest, it doesn't work.
It used to work until 3 days ago.
Anyone from ViewQwest shed any light??
When will all 200mbps plan users be upgraded to 300?
Yup, freedom VPN. Seems like freedom VPN had quite a bit of issue of late.![]()
Ah, SingTel has a point of presence in London which explains it.
I don't think the other ISPs have a PoP there so… well a bunch of users have asked for a Europe PoP so I hope we get that someday.
Well that or AMSIX, there aren't many quality PoPs, though of course many patch into AMSIX from outside AMSIX via cheap local L2 but that's probably too much jargon for a HWZ postHehehehe... An EU PoP does not necessary have to be in London.
Choose wisely...
Have you contacted NOC? Would be best to contact NOC so they'll open a ticket and keep you updated.Please ViewQwest... Look at fixing HBO-GO asap. I am burning up a subscription I can't use.
Anyone upgraded to the 1Gbps plans? Is the pricing finally sweet enough to take the plunge?
