mine drain faster
about 30% faster
same here, my battery drain more than 4.2.2
mine drain faster
about 30% faster
Where is the dev option/ protect sd card ? I cannot find
mine drain faster
about 30% faster
Cannot, dont know y cannot save anything in sd card.haiz
wah..interesting....go to about phone, tap on *build number* several times
For those who battery drain faster, you may want to do repairing through ***. I done it and now it almost same as 4.2
Ralph the option show but is not protected, I cannot save anythinh in sd card. But if I use pc connection, I can save photo in thr sd card.
juz curious wat u wanna save into teh card?Ralph the option show but is not protected, I cannot save anythinh in sd card. But if I use pc connection, I can save photo in thr sd card.
Help. My waterproof casing for the charging cable catch is broken. How much to get it replaced?
how to enable the Chinese input after upgrade?
:found.
Ô×°Ë÷ÄáC6603 lt36i L36H Êý¾ÝÏßUSB¿ÚÈû ¶ú»ú¿×Èû ¿¨Èû·À³¾¸Ç×Ó-ÌÔ±¦ÍøHelp. My waterproof casing for the charging cable catch is broken. How much to get it replaced?
