Dell U2412M
Kusanagi
i don't do design work nor anything related to accurate color reproduction, I'm merely an enthusiast therefore i can't comment about the 2413 lol
i was tempted to get a 27" as well, but due to space constraints, I'm gna run a s2340l horizontally with either a vertical 2312 or 2412
lethaldolphin
is the 2413 much better?
I have U2413 and U2412M side by side, the color on U2413 is more lovely, which is obvious because U2413 is an 8-bit S-IPS monitor, while U2412M is a 6-bit E-IPS monitor.
Having said that, the price of U2413 is almost double than U2412M's. Unless you are doing image processing, it is not cost effective. If you are still willing to spend the money, you may want to wait for the sales.
Futhermore if you want it because it looks like the best monitor for 24", it is not, it also has have a weakness like uniformity, you should check the reviews on internet, they are telling the same story.
Compact7
The U2412M is one of best deal in this size. I always want it and wait for the px drop. Current px is very good for 5yrs one to one exchg. Too bad I saw the 2413 and 2713 which displayed much vibrant and sharper text/images with clearer matt coating. I see and use two U2412Ms almost everday due to work. So I know the diff and more I use more it become obvious.
kashix
just hooted one today to replace my S2340L! good monitor!
from tradepac, despite regular there boss quoted me best price $335 :( should have read the thread and get $325 :(
IAmZTX
Anyone can share their settings for standard and game? I am facing brightness issues using my monitor. Its hurting my eyes very badly and i had been changing the brightness/contrast settings continously for different games. This is REALLY bad. I dont used to have this issue in the past. In the past, i was using Philip 19 inch monitor, didnt have to worry about adjusting the settings. Probably just the brightness only
- How to calibrate? Just bought it a few days ago
Running in Win8.1 using MSI R9 280x
Games i played: LoL, BF4
knave
you can change the gamma setting in the Graphic options?
Kusanagi
my s2340l had this issue as well, where the monitor will adjust the lightnings according to the type of programs your PC is running, you can try and switch it to manual using the firmware/on the monitor itself
evershineoptical
Has anyone tried connecting their macbook pro retina 15 HDMI to the display port of 2413 ? where can i get the HDMI to display port converter ? what's the max resolution can you get ?
shadow84
It may not work as it needs to be active.. try using a hdmi to dvi cable instead.
Kusanagi
jialat, went down tradepac, OOS
best bargain also OOS
video pro quoted me 39x :s13:
cheapest was PCT 35x
storm913
just purchased one at 330, 5 yrs warranty, last set i believe. Anyway is it necessary for me to install the drivers? And what kind of settings should i do for best viewing experience? thanks!
tjkb230
usually is plug and play, unless u want extra functions from dell, then need to install drivers from the cd.
settings is 1920 x 1200 @ 60 Hz
kashix
I install to use the default icc that comes with the monitor otherwise will only be recognized as generic PnP monitor
Kusanagi
noooooo
where?
