[Mac 101] Ask your questions here!
wweixian
I have an older imac, going to buy mbp. Can I also download the pages etc. In my older imac?
crystalnox
New to macs here, is it practical to buy a MBA to run windows only? Was looking at ultrabooks but few were under $1.5k with ssd and under 1.4kg. :D
PetPet
Moderator
Moderator
Nope. These MBA run really warm when they are on Windows. Consider a Wintel laptop instead.
duhduhduh
Either switch to MacOSX or just get windows...
Macbooks really not ideal to run windows at all
crystalnox
I thought they ran with boot camp rather well nowadays. Anyway I shall try switching over as much as possible to OSX, really attracted to the weight and battery life. :D
Would it be better to run windows only programs through a VM or dual boot into Windows? Some programs like VS unfortunately only work on Windows. :(
chehjin
what is VS?
davidktw
Run Parallels, you will be fine :)
NewRules
Hi all.
Currently having problems with my iMac. The graphics suddenly get distorted. Random pixels upon start up. Now the screen freezes and I can't get it to work despite restarting many times. YTD was talking to an operator over the phone and did the options + restart method and it was okay. But today it doesn't work anymore. Is it a graphics card issue?
chehjin
Hi all.
mostly gfx, but could be faulty ram or mobo
unlikely corrupted HDD but its still a small possibility.
just send it in if have applecare
NewRules
HDD working fine. Managed to do a disk check. Apple care expired. Hope the replacement is cheap.
NewRules
the answer is yes
check apple repairer ow much it cost
than post back ere
i help u sourced alternative far cheaper
I tried calling but the call center is closed on Sundays. Will check tmrw.
Thanks man! Happy that you will help a complete stranger :)
NewRules
u r not the FIRST one i assist...
all over the ear i help MANY for ZERO dollar$
incl a couple of posters from this apple clinic
Thanks! So I got off the phone with the service center from Wheelock. Diagnosis is already $120. Replace the graphics card is probably $300-400. Very ex man.
