The Galaxy Note 3 thread, also stop asking me if it fits in pockets.
NeonX
Android OTA updates are rolled out in waves. If you don't get in the first wave, then no matter how many times you press the update button, you won't get the update. You'll have to wait for the second or third wave. The surefire way to get the update is to use Kies 3.
can't upgrade with kies also, says GALAXY Note3 (SM-N9005) does not support :(
Oinkize
then maybe my set is due for updating except that i was not being prompted.
kelvinti
I'm waiting for my wave of update of Galaxy Gear now after my Note 3 update...
NeonX
Wa seh. I guess that the service centre is waiting for you liao...
Kies doesn't support Galaxy devices from Android 4.3 and up. You need Kies 3 for that - Kies | SUPPORT | SAMSUNG <- look below the link for the original Kies to find Kies 3.
i'm using kies 3.
it only shows not supported when i go into firmware upgrade/initialization. Other than that its detecting my phone fine, able to xfer files etc all ok...
damn weird
Rui2
Has samsung remove the "swipe up" motion of their irritating magazine app in Kitkat?
thanks
NeonX
Nothing wrong with my firmware and stuff right?
NeonX
Nothing wrong but there is a new firmware for note 3 :)
not available to me OTA or on kies3 tho lol.
kies 3 will show my current firmware and say no update firmware available.
when i go to firmware upgrade/initialization manually, it will say SM-N9005 not supported
Oinkize
Maybe your phone not on xsp?
kelvinti
Samsung has not configured KIES 3 to support Kitkat update via computer yet or has not pushed Kitkat into KIES 3 yet, either way ba...
So, you can't update to Kitkat via KIES 3 yet at the moment.
