Computer Upgrade (Budget ~900)
egantay2
Hello , i have been thinking about upgrading my current pc . If i am going to do this i am going to have to change a mother board and case before i get another GTX 770 to sli . Right now i have a few questions , when motherboards say they are amd crossfire capable.. does that mean it can do sli as well? I would really appreciate it if you ladies and gentlemen could recommend me a good LGA 1155 motherboard that is in the below $200 range for sli. I am planning to go with a Mid Tower Case so if anybody has any suggestions on what case to get please do feel free to leave a post :) . I believe my PSU is At least 750W but i forgot since the last time i check was when i was changing my gpu from gt 545 to my current gtx 770 . Please do advise me on what to get and avoid . My main goal is to get another Gigabyte GTX770 windforce edition to sli .
I am planning to spend the money in the following way
GPU : ~$550
Case: Below $100 Range
MotherBoard :Below $200
Here are my Current Specs.
Item Details
Windows: Windows 7 Home Premium Edition (64-bit) Service Pack 1 (Build 7601)
Internet Explorer: 9.10.9200.16750
Memory (RAM): 16366 MB
CPU Info: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
CPU Speed: 3387.3 MHz
Sound Card: Speakers (Yeti Stereo Microphon |
Display Adapters: NVIDIA GeForce GTX 770| RDPDD Chained DD | RDP Encoder Mirror Driver | RDP Reflector Display Driver
Monitors: 1x; Generic PnP Monitor |
Screen Resolution: 1920 X 1080 - 32 bit
Network: Network Present
Network Adapters: Intel(R) 82579V Gigabit Network Connection | Hamachi Network Interface
Manufacturer *: American Megatrends Inc.
Product Make *: Predator G5910
AC Power Status: OnLine
BIOS Info: AT/AT COMPATIBLE | 12/22/11 | ACRSYS - 1072009
Motherboard *: Acer Predator G5910
Thank you for taking your time to help me with this little project of mine . Haven't really completely taken apart a pc and put it back together before so this would be good experience for me since i am a Comp & Networking Student :)
localITguy
Suspended
GPU : ~$550
Item Details
if the mbo say support SLI is only SLI no crossfire support. unless they say both SLI and crossfire
i dun think you need to upgrade, your specs still berry gud..
LGA1155 is going to be gone sson le, not worth it
shadow84
Actually, all mobos with 2 pci-e x16 slots can do crossfire, and only certain if not most z series can do SLI.
To TS, download cpu-z and find out what mobo is your com using. From there, can find out whether can do SLI or not. But, you need to check your power supply as well. SLI needs at least 750-850w.
egantay2
Go amd?
Or should i just go with a amd mobo and cpu , motherboards that use amd processors are not gonna restrict you to only using amd GPUs right?
86technie
TS you are using Acer Predator G5910?
There might some limitations of the Acer motherboard
and also the power supply if you want to do dual gpu.
To me there's nothing you need to upgrade so
maybe you wanna try reformat your system?
Btw what games are you playing currently?
egantay2
i know its good enough to play nowadays games but i wanna sli now and futureproof it for the next few years . I play almost all games but mostly play DayzSA, Dayz , Rust , Waiting for TitanFall , BF4 and alot of other games that i am too lazy to list :)
egantay2
hmm maybe i will change mobo and go amd . Get a new Mid Tower ATX Case and use the other parts from this current build.
MoneyFace =p
Don't be foolish, going AMD from your Sandy Bridge Core i7 is a downgrade in almost every way... And not all AMD motherboard will support SLI, only high-end ones just like those Intel based ones will offer them.
Just get a new SLI-capable Z77 motherboard, a new 650-750W PSU (if current one isn't high enough) and a new chassis, and reuse everything else. Save yourself from unnecessary investment, time and effort try to achieve your initial goal..
A good contender within your budget would be ASRock Z77 Extreme4...
egantay2
Hmmm alright then , i will go walk around sim lim to try find that mobo . The forum does not recommend videopro online store right?
egantay2
You are talking about this one right? Video-Pro.Com Pte Ltd
shadow84
Dun use video pro website to compare... just use asrock website??
ASRock > Z77 Extreme4
Can go look in tradepac, pc themes, mynextcom, best bargain, fuwell, best buy. Go see which offers the cheapest. But note that it may be charged higher due to now getting a whole rig.
To know whether support SLI or not, go look at specs in manufacturer website. Look under PCI slots category. It will state whether can do crossfire or SLI or both.
Also, if u are going for SLI, need min 750w, plae safe 850w. Dun go beyond 850w for 2 cards sli.
egantay2
I think I will get that mobo bah. After lunar new year go sim lim walk walk. GONG XI FA CAI, XIN NIAN QUAI LE!
shadow84
Z77 Pro4 cant do SLI, Z77 Extreme 4 can do SLI. Go do research before spending ur ang bao money on something that you got wrongly.
Felfirez
I think you read up more and think about it before doing SLI. I'd rather you spend that money on something else or save some of it for a GPU upgrade in the future. From the way you're replying, seems like you're totally clueless to what's going on and had not done your research.
If you encounter any issues with SLI configuration, or don't even notice that you need to keep updating your SLI profile/firmware, it'll be a hassle/waste than an upgrade.
