Rocket3
- May 18, 2012
Hailgod said:That is irrelevant. Your computer isn't using ram as it should be, more like using it as a very fast solid state drive.
Yes, put the Windows swap file on the ramdisk. This gives much faster performance than having the swap file on SSD or HDD.muddle said:Rocket3, you are basically telling him to create a ramdisk out of the unusable memory. I believe ts want to utilize the full 8gb ram in 32bit os. Which is not possible unless you use the PAE switch.
TS needs to take note that using the 64-bit version of Windows has its own disadvantages. Like you cannot run programs with 16-bit code.
