Desktop PC for Graphic Desginer
FFForever
Need help on what to get for a Desktop PC for graphic designer.
My Budget is around $1k to $1.5K.
I will be using Adobe CC: Illustrator, photoshop, InDesign.
Any recommended Specs? Is i5 core good enough??
Thanks.
royfrosty
You will need an i7 and 16gb of rams.
Msi b85m g43 + i7-4770 ~ $475
Crucial 8gb 1600mhz x2 ~ $178
Wd blue 1tb ~ $76
Plextor m5s 128gb ~ $128
Zotac gtx760 2gb Amp! + superflower hx500 500w 80+ gold ~ $429
Sharkoon BD28 ~ $77
Samsung odd ~ $21
Windows 7 home premium 64bit oem ~ $115
Total ~ $1499. Buy at tradepac. Diy
Hailgod
Wd blue 1tb ~ $76
Sharkoon BD28 ~ $77
Samsung odd ~ $21
windows 8 would be better if you plan on upgrading to 32gb ram in the future. Windows 7 home premium only supports 16gb of ram while 8 has 192gb limitation.
royfrosty
7 has 192gb support also.
But must be professional and above.
FFForever
Wd blue 1tb ~ $76
Sharkoon BD28 ~ $77
Samsung odd ~ $21
Is there any ready built PC outside, as THe PC is for my company.
Or it will be better if I Built one myself...
