AnDyLe0
- Apr 13, 2006
i bought Draco tuner, everything test ok so far. Signal is high. One thing I would like to check is - for the recording function, is there any way to adjust the quality of recording? I couldnt find this option.
recording is in TS (transport stream) format, i.e. 100% full quality. (what u recv from the air is saved into the TS file)
u can then use any video converter to convert to mp4, select audio, select subtitle or lower the quality.
