bsod
jiaweiii
Need help when watching suddenly comp blue screen . After i reset it when boot it shows reboot and select proper boot device
jiaweiii
Okay will try it after i get home should nt be hdd problem ba os is installed in ssd though
jtjt00
Try disconnect storage drive and see if problem persists.
jiaweiii
seems like memtest86 need buy one leh . And anyway new findings when i try to start comp i will always go to the problem thingy but when i reset and go to bios and go nothing and leave bios my comp will be able to boot
Zadkial
I tot it will auto run and finish, then press any key to quit?
If you wanna check for errors and stability, recommended is overnight. Do about 4-5 passes on memtest.
If you really concerned then 24++ hours. :s13:
shadow84
Only did 1 run, den no errors den restart com. Working le. I oso kena BSOD when surfing internet...
jiaweiii
okay will probably let it run till tmr morning . will update about the situation again tmr but i suspect its my usb problem or either my ssd problem not really sure
Zadkial
Its mostly up to you la. If you think you happy with 1 run then okay la. :s13:
People usually do more because they wanna make sure it's not the ram thats causing the problems.
shadow84
Will take note next time i kena BSOD.
jiaweiii
anyway suddenly got 2 unknown things appear on my ssd (hiberfil.sys and pagefile.sys)
Zadkial
hiberfil.sys is for hibernate mode for your pc. Can disable it if you want. Just do some quick googling.
pagefile.sys is your virtual memory. That one i not so sure if you should disable or not. Should stay safe and dont touch la. :s13:
Maeda_Toshiie
You can disable the pagefile, but if the total amount of memory required by Windows and all running applications is more than the amount of system RAM available, it will result in a hard system crash, instead of hdd trashing. Note: putting the pagefile in a RAM drive is a redundantly dumb move.
