Galaxy Note 3 4.4.2 Kit Kat update
KlooLess
Just updated to build N9005XXUENB4, my 3rd party camera app (Camera Awesome) still cannot write to SD card :s11:
gapboy
N9005XXUENB4 4.4.2 KitKat Update Details and Changelog
- Software Update to 4.4.2 (KitKat OS)
- New start setting menu.
(Start-up screen, SMS)
- Camera shortcut added in the lockscreen.
Security Enhancement and Stability Update.
- External SD-card fix
- Other changes may depend on the country or the mobile network providers.
- Once received the 4.4.2 KitKat update, you can not revert back to the old software version due to the new security policy guidelines.
http://androidromupdate.com/tag/n9005xxuenb1/
timmy75
N9005XXUENB4 does not fix my issue of file operations in ext sd card using ES File Explorer and MX Player Pro. Not sure whether it fixes high battery drain due to pdf files in ext sd card. It probably fixes usage issue with sandisk sd card...i'm using samsung 64GB plus which I bought at a discounted price of SGD 79.
ATN888
PC Odin from NA6 to NB4 this morning.
- nair notice any significant change
- now NFC scan Ezlink using FareBot
So what's the fix on extSdcard? ... my Esfile still taboleh create folder (Scandisk64), still have to use built in filemgr.
ProGamer84
Super update nothing changes at all.. My s-view not working.. Every time need to reboot or took off the sav case and put it on again then will work for few mins... ****ing lame update by Samsung... :(
kchinbeng
I have no such issue using 3rd party casing also
karlheng
I flashed Polish NB3 on my Singapore phone. The S View function on my 3rd party case has been quite stable. For once or twice initially, I had needed to power down and replace the case for S View function to work.
See Firmwares | SamMobile | Page 3
wonga1972
after updating the latest firmware battery life like not that lasting anymore leh, any one feel the same way also?
kelvinti
It's time to factory reset my Note 3 after NB4 for a fresh, or rather a refresh new start!:s22:
jim123
My third party s view works but at times it take about 5 seconds before the screen sleep or wake.
